Position Vs Time for LVDT
aeastet
This is what I want but I can't get it to work off my data array without the data you generated.
I have a constant array that simulates the curve and I can't get it to do what you did with the xy graph or even to display the different peaks time so I can then take the delta time.
JCollado
Message 11 of 21
(1,835 Views)
You may need to set the limits higher or lower depending on the magnatude of your data. If you send me some data I can see if I can get it to work on your data.
Tim
GHSP
Message 12 of 21
(1,833 Views)
Here is the VI i'm testing this on with the array for simulated curve.
Maybe the Array does not have enough data points?
I added your controls and block diagram functions.
Sorry about how ugly this looks but I have added a few other things that are getting me some info i need.
Just click the get signal button to get the graph data.
JCollado
Message 13 of 21
(1,824 Views)
I took the hard coded array that you had in your code any took it into my VI. I changed the peak threshold to .05 and it seemed to work. I added it your your VI and aslo made it look at the last sample to get the final condiditon. Here are both.
Tim
GHSP
Message 14 of 21
(1,816 Views)
I took the hard coded array that you had in your code any took it into my VI. I changed the peak threshold to .05 and it seemed to work. I added it your your VI and aslo made it look at the last sample to get the final condiditon and I changed the peak threshold to .05 and made it the default value. Here are both. I could not test it on yours because I did not have all of the VI's needed. You may need to set the threshold on my VI to .05 as I am not sure if I canged it to the default value.
Tim
GHSP
Message 15 of 21
(1,816 Views)
Accepted by topic author JCollado
I had to disconnect your type def at the top but I did get yours working with this idea. See attached.
Tim
GHSP
Message 16 of 21
(1,811 Views)
Great!
Thanks a lot.
I have much to learn. To this point I did not know how to use the XY graph. I guess in order to automate time measurement like this I must use an XY graph?
no way to do what you did with a regular graph or chart?
Thank you
J Collado
JCollado
Message 17 of 21
(1,801 Views)
Here is more or less what I was looking for using the waveform's cursors.
I just took the derivatives solved by AEASTEST and displayed the time as I wanted it displayed.
Thanks for your help AEATEST.
JCollado
JCollado
Message 18 of 21
(1,789 Views)
No problem. I was fun to develop something like this. I am sure that I will need this in the future.
Tim
GHSP
Message 19 of 21
(1,780 Views)
 aeastet
Using the same idea on a different project.
I can't get the second derivative to work with  a larger sample size.
Not really good with all the higher end math functions . 🙂
See the attached VIs in the zipped file. I added all required VIs to run this. If it ask to locate a VI they are all in the same folder. This is working but not the way I want it to work. The cursors are going to the location I want them to ecept I would like to place them on locations that is different every time.
This VI will almost do the Job but I do not like to place the second cursor on a specific location for the snubbing. The snubbing starting position is a variable position for different actuators.
I would like to do this the same way you did the previous VI using derivatives . Any way you can wire this to work with derivatives functions?
Thanks for your help.
JCollado
JCollado
Message 20 of 21
(1,468 Views)
