Populating Strings[ ] on a menu ring
I have a menu ring inside of a cluster. The cluster is embedded in an array. So essentially I have an array of clusters where each cluster has just a menu ring inside of it. I'm trying to programmatically populate the Strings[ ] property for each menu ring, for every array position. The Strings[ ] property for each menu ring will be different for each array position.
I can't see any way to do this programmatically? There seems to be no way to access the Strings property when the menu ring is embedded in this manner.
(2,634 Views)
I tried that long time ago, no way until some geeks will find a way ....
My workaround: Since I wanted it for a configuration setup screen, I made a seperate popup window for the selection.
Greetings from Germany
Henrik
LV since v3.1
(2,627 Views)
