PopUp-Menus
Hallo,
I attached a VI with a PopUp-Menu. It has four buttons:
a) empty cylinder measurement
b) sample measurement
c) exit measurement
d) always
My task is:
1) In the beginning every button should be set to "false"
2) a) and b) cannot be true at the same time. (f.e: if a) is true and b) is false and I push b) than a) is automatically set to false.)
3) If c) is true the program stops.
4) If d) is true than the value of a) and b) stay the same until the program stops.
Task 3) I solved by connecting to the conditioning terminal. If you attach a VI in your answer please convert it to LabVIEW 6.1.
Arno
(2,694 Views)
Try this VI. I put it in a Cluster, to make the code cleaner. I used a xor
to get a "change" signal, that is converted to a change index with the
search 1D array. This way, you can determine the behaviour per button.
Wiebe.
"ASCologne" wrote in message
news:506500000008000000E6EC0000-1079395200000@exchange.ni.com...
> Hallo,
> c) exit measurement
> d) always
> My task is:
> program stops.
> Arno
[Attachment Boolean Cluster.vi, see below]
(2,694 Views)
