Poor Curve Fitting issues
I tried to fit a curve in LV 8.2.
I don't know why the result (attachment) was so bad and remained the same in the different weights of "general polynomial fit.vi".
Although I can't find the manual about mathematical functions, I expected the curve was well fit in start/end region with some weight.
In order to do, I made the weight (0.5 nearby middle and 1 start/end region) , but the gap in start/end X region of the attachment was rather big.
In Origin , commercial fitting program, the result (attachment) was sufficient to use in other application.
What's the different between LV and Origin?
*)Annotation of red in color  in LV and Origin was incorrect in the attachment.
메시지가 07-08-2008 09:11 AM에 labmaster에 의해 편집되었음
(3,180 Views)
Can you upload your data, and the snippet of code that you did. It seems to me that this Origin program isn't doing a curve fit at all, but rather a tracing, which is something completely different.
(3,153 Views)
Thank you for the interesting.
Attachments are the demo data and my simple code in LV8.2.
(Code has a garbage for my various tryings such as derivative.)
The fitting was not changed according to weight and method in poly.vi.
The purpose of fitting is to get a base line of the graph.
The final target is to detect the position and shape (residual) of the small bumps in the graph.
(First and high order derivative was not helpful in my tryings.)
메시지가 07-08-2008 06:33 PM에 labmaster에 의해 편집되었음
(3,110 Views)
I want to cancel my posting.
There was a scaling in a graph.
(3,093 Views)
OK. So presumably the LabVIEW curve-fitting worked for you then?
(3,059 Views)
