Polymorphic selection
If a polymorphic vi has ten function is there a way to select correct function base on user input without a case structure?  Thanks!
Yik
(3,891 Views)
A ploymorphic VI is the one that "can adapt itself to diffrent data types".
So why the case structure is required? You have to select the option "Automatic" or Auto and just wire the input...
Regards
Guru (CLA)
(3,879 Views)
hmm, the auto option sounds interesting.
Yik
(3,858 Views)
You do know there's a manual right?
(3,846 Views)
I knew about the auto option, but I just never connected the dot.  Anyway, I can't use the auto option, since the input for all of my instances are of the same type, only the outputs are of different type.
Yik
(3,840 Views)
It would probably be best to keep this discussion in one place so people know what this is all about.
(3,838 Views)
I split that out, because I thought it is a side question, but I will try to keep it together next time.
Yik
(3,833 Views)
