Polymorphic ActiveX Methods
I'm trying to whip up a Labview VI to interface to some existing VB
ActiveX servers.
The problem is that my servers use a class factory approach. For
example: say I have three visual basic classes like this
' class base
public sub aMethod
end sub
' class derived
implements base
private base_aMethod
.... ' my implementation of aMethod
end sub
public MySpecialMethod
' method available only though a reference to class derived
end sub
' class factory
public function MakeInterface ( byval iType as integer ) as based
select case iType
case 0: set MakeInterface = new base
case 1: set MakeInterface = new Derived
' and so on
end select
end function
Now, in vb I might write:
dim f as new fac
tory
dim b1 as base
dim b2 as base
dim d as derived
set b1 = f.MakeInterface(0) ' returns an object of type Base
set b2 = f.MakeInterface(1) ' returns an object of type Derived
set d = f.MakeInterface(1) ' also returns an object of type Derived
b1.aMethod ' legal
b2.aMethod ' also legal (calls the implementation in derived)
d.aMethod ' illegal (aMethod only available through base interface
d.MySpecialMethod ' legal
b2.MySpecialMethod ' will probably work due to late binding.
The problem I have is using the above approach in Labview. I call
MakeInterface with no problems and the Automation refnum returned is
for an object of type Base.
But, given that I provide a parameter of 1 to MakeInterface, I can't
find a way to get at "derived.MySpecialMethod".
How can I cast a reference to base into a reference to derived? This is
especially important as I need to handle activex events which are
specific to the derived class!
Keith Derrick
Sent via D
eja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(2,698 Views)
