Polygon input from user through front panel in runtime
Hello!
I am trying to find a way to take a polygon as an input from the front panel. There are two parts to the problem, first is to take the 'hand-drawn' image from the user through the front panel and second is to convert it in a polygon. How can i do the first? I can't find any option in the graph/2Dpicture properties.
Thanks!
(1,729 Views)
Hi Robin,
What have you tried so far? Where are you stuck?
When it is about graphs:
  • They support cursors so you could use a cursor to have a user move and set it. You can read cursor properties all the time…
  • You can always use an event structure to handle mouse movements/button actions for a certain control like a graph…
When it is about basic frontpanels: use the event structure to handle mouse movement/button events…
In the end you should know the coordinates of interest: what is the your problem to create a polygon from coordinates?
(1,698 Views)
Here is an ancient example using an XY graph and cursors.  You click in the graph to add a new point and can drag the existing points around.
https://forums.ni.com/t5/LabVIEW/How-to-select-a-set-of-points-in-a-xy-graph-contained-in-an-area/m-...
(1,665 Views)
