Polling
Hello.
Is it possible do a polling in the meanwhile the Labview is in a "while cicle" in which there is  a Elapsed Time Express VI. What I want to do is while I'm waiting for the responce of an instrument  at the same time do the polling of another one.
Thank you
(3,432 Views)
while circle means while loop?????????
loop is polling if you use Elapsed Time Express VI.
if you have 2 instruments and they both give responce at different time you should use 2 parallel while loop
(3,424 Views)
Hi inu,
use parallel loops für your devices...
(3,419 Views)
Upload VI or some iimage so that dubgging can be done
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,377 Views)
is there any guide that explain this?
I tried to open two different visa in 1 while cicle and I see that I lost the control of both of them... so I need to fix this thing.
Ranjeet you saw the first one today the other one is crazy ^^
(3,347 Views)
