Polling through multiple files
I have multiple files from our experiment which are named as per sequence no like: T2789_MM_DD_YY_hh_mm_ss.xlsx.
We have around 10000 such files from experiments running for quite some time. For data analysis we are developing a automated LabVIEW based tool to display data and apply some algos.
The issue I am facing is that for few sequence numbers the polling takes a lot of time and I have to manually segregate some data in a folder and then select some sequences.
can anyone suggest any other fast or efficient way to filter required files (based on sequence number) other then polling.
Thanks a lot.
(2,518 Views)
What you mean with "polling", precisely?
Paolo
(2,487 Views)
Hi falcon,
The problem is either in your VI or in the data file.
You didn't attach anything: what kind of help do you expect?
(2,481 Views)
Assuming you with 'polling' are using some 'List files' there's a couple of things you can do. You have a fixed format, so you can use that as a filter in your List files function to e.g. only list files from the current hour.
You should also separate files into folders so you only have e.g. 1 day (or 1 hour) Worth of files in a single folder.
Qestit Systems
Certified-LabVIEW-Developer
(2,475 Views)
I think  I need to add some more details.
By polling I mean to filter out desired file paths from all the available files. Like I said I have 10k files and I need around 100 files at a time for analysis (for the tool).
So for the analysis to begin I need 100 files (selected via sequence numbers) from the available 10k files.
I am attaching a snippet for your reference.
Can I use some dll file for filtering the required file.
pls let me know if I am not clear.
(2,428 Views)
Hi falcon,
From ListFolder you get an array of filenames.
Use ArraySubset to get an array of the required amount of filenames, then start your "file analysis" with these files…
(2,402 Views)
I guess that H: is a network mapped folder. Are you sure that the delay does come from the filtering and not from the folder reading?
In any case, your code is doing a lot of unnecessary work. For 100 selected numbers and 10k files, the total number of iterations is 1M.
Since only one file can match the requirement for a given number, you can do all in a single loop over the 10k files.
My code below removes each found number from the number list: this is probably an overkill optimization that gradually speeds up the search and makes the loop to stop as soon as all required files are found.
Paolo
(2,389 Views)
