Polar Plot.vi
Hi. I have the problem. How can I create two different colors for two different plots?
Thank You.
Dmitry
Moscow
(3,252 Views)
You will have to explain what you are trying to do a little more
- there is always an easy way, but it is always the hardest to find
(3,242 Views)
(3,213 Views)
The polar plot vi draws two images, the grid and the actual plot by using a vi called draw multiple lines.  Unfortunately, the function that draws the polar plot only allows for a single color, as shown in the image below:
RayR
Message Edited by JoeLabView on 06-23-2008 08:26 AM
(3,197 Views)
Perhaps you could move the draw multiple lines vi to inside the for loop. Replace it with a draw line vi. Feed the picture around the loop with a shift register and write to the same picture multiple times. This would let you use the color input to the draw line.vi with a different color for each iteration. Might have to manipulate or reorder the data that you are sending.
Also see this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=134753&query.id=28545#M134753
Message Edited by unclebump on 06-23-2008 10:40 AM
(3,183 Views)
