‎12-30-2009 01:28 PM
Hello all... Is it possible to connect my Compact Field Point Controller to a PoE switch (Power over Ethernet Switch)??? This is because some other devices on the same subnet require PoE (IP cameras) and I wanted to know if this can cause some sort of problem with my Cfp... Should I connect the Compact Fieldpoint to a regular switch and connect that switch to the PoE switch??
Let me know any suggestions...
Thanks a million in advance,
‎12-31-2009 01:53 PM
‎01-05-2010 09:24 AM
Hi Jaime!
Currently there are only certain products that support the PoE standard, unfortunately the cFP family is not one of them. The best you can do is connect your cFP to a switch and then to the PoE switch like you said and check if that works. Here is the document where the PoE and NI products are described:
http://zone.ni.com/devzone/cda/tut/p/id/9847
Hope this helps!
Have a great day!!!
