Plug a new usb sound card while LabVIEW is running
I work with some usb sound card to do audio measurements. The problem is that when I unplug a card and plug another one I have to restart completely LabVIEW to be able to use the new sound card.
Is there any way to detect and use a sound card plugged while LabVIEW is running ?
Message 1 of 16
(6,096 Views)
i assume that you are using VISA to communicate with your USB devices.  As shown in this post
 you should be able to detect your USB Devices with the VISAfindResource.VI
USB Instrument Control Tutorial:
 http://zone.ni.com/devzone/cda/tut/p/id/4478
Regards
Naitsabes
Message 2 of 16
(6,051 Views)
I'm only using the LabVIEW 'Play Waveform' function. It works well until I unplug and replug the USB sound card. Then, if I try to execute the VI again, it fails with this error message : "Possible reason(s): LabVIEW:  (Hex 0x12C0) Selected Device is Invalid".
I've tried to change device ID from 1 to 5 but it doesn't work. I'm able to detect the sound card with some 'low-level' functions and use the sound card with 'Windows' but LabVIEW can't send any sound to the card.
Message 3 of 16
(6,045 Views)
at this point, i don't think that you can avoid this behaviour with non NI-Devices, but maybe you could give us some more informations about your application so i can furhter investigate.
-Which card(s) are you using?
-In your first post it's said that you unplug a card and plug another one.  Why can't two cards be connected at the same time?
-The seconds post says that you un- and replug the same card.  -> Why?
Regards
Message 4 of 16
(6,005 Views)
Why do you unplug your sound card? If you have to few USB ports, maybe an USB hub can solve your problem. Use the hub for the slowest devices like mouse, and keybord
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 16
(6,002 Views)
- I'm using M-AUDIO transit USB sound card
- I need to test a lot of a cards. So even using 4 at the same time wouldn't b enough.
- I would like to be able to change to another sound card or to use the same.
Regards
Message 6 of 16
(5,981 Views)
the problem is, that everytime you'll conecting a new device, it will get a new identifier from your OS. That's part of the USB specs and how the OS is handling new devices.
LabVIEW and other software, can't directly access the new device, this happens only in the initialising step on startup.
Have a look at this:
http://www.m-audio.com/index.php?do=support.faq&ID=02efd1f395afa276d4ea08a646e34e90
maybe a USB Hub can help
Tobias
Message 7 of 16
(5,969 Views)
HI,
    I am having a simular issue with a USB headset that we are testing using the Labview Play Waveform fuction.  When the device is unplugged and then plugged back in from the PC we have to close Labview and reopen it to again use the play waveform VI to send a tone to the headset.  We have not yet found a way around this and are wondering if you were able to find a solution?  Thanks
Scott
Message 8 of 16
(5,808 Views)
Accepted by topic author adcpc
It seems that there is a kind of workaround using this :
http://groups.google.com/group/comp.lang.labview/browse_thread/thread/0976c777e7af1be9
I just replaced the lvsound2.dll with the labview 8.2.1 dll and it is working.
Message 9 of 16
(5,795 Views)
I know this is an old thread, but I have come across a similar problem.
I have a program that tests an USB sound device, and I am using the "Sound Device Info.vi" from lvsound2.dll to check if the device has been properly connected. But it has some strange behavior.
If the device is connected when I start the program, then I can see the device in "Sound Device Info.vi", and when disconnected it disappears, if I reconnect it reappears - averything is ok.
If the device is disconnected when I start the program then "Sound Device Info.vi" cannot see the device. Disconnecting/reconnecting does not make a difference.
Does anyone know what causes this?
Will it help to replace the lvsound2.dll with labview 8.2.1 version as suggested in this thread?
Where can I get this version of the DLL - I don't have labview version 8.2.1 installed?
Hope you can help
Stephan
Message 10 of 16
(4,929 Views)
