Plotting two waveforms in a single waveform
Hey, thanks in advance for any help recieved.
I would like to plot two waveforms on a single waveform plot, so that I can compare the two as the application is running. Also I would like the time at the bottom to be the absolute value.
Regards
Alim Guy
(2,720 Views)
Hi Alim,
Check out the attached VI. I used merge signal to do it.  I guess this will help you.
Nitzz
(Give kudos to Good Answers and Mark it as a Solution if your problem is Solved;))
(2,719 Views)
Hey,
That's cool thanks, tho do you know how to plot absolute time on it?
(2,717 Views)
i.e. so you can see the complete graph?
(2,716 Views)
Accepted by topic author aguy004@aucklanduni.ac.nz
Try this one.
Nitzz
(Give kudos to Good Answers and Mark it as a Solution if your problem is Solved:smileywink:)
(2,712 Views)
