Plotting the Autocorrelation Function from a Signal
Hi everyone,
-Im trying to plot the Autocorrelation function from a random signal (see Figure1), which has been sampled at 200 KS/s and presents the duration of approximately 15 s. For the evaluation of the Autocorrelation of such a signal, I´m using the "AutoCorrelation VI" in Labview 2010. When I plot the signal´s Autocorrelation with a "waveform graph", what I get is a triangular-like graph (see Figure 2), which does not match the form of a regular Autocorrelation graph for a random signal (see Figure 3).
-How can I plot the signal´s Autocorrelation, as represented on Figure 3, (where the x-axis shows the time delay) ?
any help would be highly appreciated,
best regards!
(6,129 Views)
Do figs 2 and 3 show the result of processing the same input data?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,112 Views)
Can u send an example of your vi  ? With the data you are trying to plot ?
To plot a graph with the X as time, you need to add information to the graph like delta t, (interval between the samples) that you do using a property node. If you can post your vi, it will be easier to help.
ricardo
RKO
(6,098 Views)
Hi Mike,
-Thank you for your prompt reply.
-Figure 2 shows the Autocorrelation´s result based on my input data. The input data is ploted as detached on Figure 1. Figure 3 is just an example (from Labview Help) which I´m trying to plot with my VI and also matches a regular Autocorrelation function.
thank you in advance,
best regards!
(6,071 Views)
Hi Ricardo,
-Thank you for the hints and your prompt reply.
-Attached to this reply, I´m sending you an example of my VI.
-I´ll try to implement the proposed solution you mentioned. I let you know about it.
best regards!
(6,067 Views)
Your figure 2 shows the  autocorrelation of a signal with a non-zero mean.
Lynn
(6,060 Views)
Hi Lynn,
-Thank you for this tip and your VI. It makes sense.
best regards!
(6,026 Views)
