Plotting points of different colors and sizes
Is there a way to plot several points of different colors and sizes?  Like small sizes would be green, medium sizes yellow, and large sizes red?  I have tried using XY plot and Plot Multi-XY, but I'm not having much luck.  It seems like there may be a way to do it with Plot Multi-XY if I use the XY Plot Cosmetics and the Sized Scatter Plot Cosmetics, but I can't find anything about how these two options work and it hasn't made much sense to me when I'm just playing around with it.
Thanks!
(2,954 Views)
Hi txsmall,
use one grpah with 3 plots. Set the properties of the 3 plots (pointsize+color) to your needs...
(2,948 Views)
Accepted by topic author txsmall
Gerd has the right idea.
Say you have 3 ranges: < A, A-B, > B
You would check each data point as it came in, to see which range it fell in.
Build 3 seperate arrays, and cluster each one vs a 1D array of the corresponding X values.
Then if you pass those 3 clusters to an XY graph, you will have a graph that shows different colors/styles for each range.
Cory K
(2,933 Views)
