Plotting data from a text file in LabView 7.1
Unless you are emotionally attached to an xy-graph for the purpose of having multiple plots, I have another idea.
How about you split up the array into 8 colums (or just index each colum):
1 - > time
2 -8 --> each of the other columns
This way you could use a 'waveform graph', and have a graph for each of the columns of data.
You could give that a shot I guess.....
Cory K
Message 11 of 15
(2,773 Views)
Heres what I was talking about before.
You can just index each column.
It will use time as the x-axis and the selected column as the y-axis
Message Edited by Cory K on 09-18-2008 01:29 PM
Cory K
Message 12 of 15
(2,769 Views)
Cory,
It is worth a try.  Believe I know what you are saying and will try something like your suggestion.  Guess I was looking for an easy way, but guess those are more than one can count in this world.
Thanks for you assistance,
Bill
Message 13 of 15
(2,762 Views)
I also forgot to mention. If there are any columns that are related and you would like graphed on the same graph,
you can bundle the arrays then wire the output of the bundle to the waveform chart
Cory K
Message 14 of 15
(2,748 Views)
thanks!
Message 15 of 15
(1,962 Views)
