Plotting Multiple XY graphs in real time
Accepted by topic author NickIke1
replace your "Built array" with "build cluster array". (and redo the incorrect indicator)
Also, you really only need one NaN constant, not four!
Message 11 of 14
(962 Views)
Altenbach, Thank you!  I knew there had to be a simple solution. Please see the image below - is this how you would use the NaN's?
Message 12 of 14
(951 Views)
And again, just replacing the point cluster with a complex value simplifies your data structures. The rest can stay the same!
Message 13 of 14
(950 Views)
No. You still have way too much duplicate code. You only need one bundle and one initialize array. You can split after that.
Message 14 of 14
(946 Views)
