Plots on XY Graph
I have an XY graph with several plots on it.  The plot has two Y axis.  Using a property node I can change the name on the plot for each curve/data-set (Act.Plot, Plot.Name)  Now I want to change some of the plots from the Y-axis on the right side to the left side Y-axis.
I imagine this has been answered but I have not been able to incant a proper search phrase to find out how to set what property in what way to get a plot to switch from one Y scale to the other.
Any suggestions appreciated.
(4,238 Views)
Go to the properties of the graph and look at the plots tab.  On there is a spot where you can change which Y-axis is associated with a plot.
(4,223 Views)
I found that method; I should have mentioned it.  I am looking for the way to swap axis while the program is running.  I have seen it implemented.
(4,221 Views)
Property nodes execute top to bottom, so first select the active plot and then give it the desired y scale index. (make sure the selected plot and axis actually exist)
(4,219 Views)
Accepted by topic author anonamouse
Here's what I had in mind. Modify as needed. (This is for a waveform graph, but the same applies to xy graphs)
(4,212 Views)
That’s it!  Thanks a bunch.
(4,192 Views)
