Plot the last set of data ( 1000 samples ) in a loop
You need a buffer that can store more data.  If you leave the Chart inside your "While loop", as somebody pointed out above, you can extract the history using property nodes.
A shift register inside your loop is one way to do it but the simplest buffer is a Queue (FIFO) and you can then read all of your data afterward (be careful not to store hours in there or you'll run out of RAM).  You should also look into "circular buffer" that already exist (examples here: https://decibel.ni.com/content/docs/DOC-13643 and here: https://decibel.ni.com/content/docs/DOC-10355.
Good luck.
Olivier
Message 11 of 13
(419 Views)
Thanks Oliver.
How about for a digital waveform. Is there anything like circular buffer to read all of my digital waveform data afterward
Message 12 of 13
(414 Views)
Just adapt one of the other VI.
Sometime, you actually have to write some code to get the exact functionalities that you want.... 🙂
Olivier
Message 13 of 13
(410 Views)
