Hello Chilly Charly,
"While developping your own experience with LV, never forget to keep your diagram tidy. NEVER wire under an object, and always wire from left to right."
Yes very true. Your code does look neat and clean. In fact after I uploaded the code, I was wondering if I should have kind off cleaned it up - p[articularly when posting to a forum. I have learnt that tidiness is very important in LV coding as it can at times make the difference between a clear and unclear implementation. Not only that, keeping the code tight and compact, makes for easy review - if there is need to use the scroll bar to view code, then I think it is time for some housekeeping.
Best Regards
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
