Plot in Waveform chart
I don't want the users(operators) to edit the plot name in waveform chart during run time. Any property node or any way is available to do it. Photos attached
(3,484 Views)
Yes, there is a property for this. If you create the Property Node for your Waveform Chart, and select the property under:
Plot>>Plot Name
 Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(3,455 Views)
Actually you miss understood my question. I am aware of how to change plot name  pro-grammatically. But what I am asking is I don't want the plot name is in editable mode(any time I can able to change the plot name by simply select and change it - I don't want that).
I am looking to block the editable mode of plot name of waveform chart during run time.
(3,440 Views)
try the "disabled" property
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,436 Views)
Accepted by topic author Kannan_Kn
(3,434 Views)
