Plot discontinuous data in labview graph/chart
I would like to plot discontinuous data in a graph in labview.
The data is aquired and plotted over time - butduring certain periods there is no data aquired.
I don't want during these times any "line" between the adjescent points - I just want simply "no line".
Maybe the best way to show it is this example of a javascript chart
http://www.highcharts.com/stock/demo/data-grouping
- zoom into the time around november 2005
During certain times there is no data - this is implemented in the datastream as "null" instead of a vaild floating point number - similar to NaN for floating point numbers - the javascript code knows that in this case there should be no interpolation.
Is there any way to have a similar behaviour with labview charts or graphs ?
(3,574 Views)
Yes.  Place an NaN value in the array where you data break is before sending it to the graph.
(3,572 Views)
