Plot Visibility
The plot visibility check box is not showing up.
Please Advise.
Dan Shangraw, P.E.
Message 1 of 9
(4,873 Views)
My guess is that you have resized or moved something so that the checkbox is now behind something.
Try selecting the control and then selecting "EDIT > CUSTOMIZE CONTROL" and then click on the little wrench.  Sometimes this will show you things that you can't seem to find.
http://www.medicollector.com
Message 2 of 9
(4,863 Views)
I was thinking it was behind something as well.  I have looked and looked no dice.
I tried the custom control trick.  No Luck.
Dan Shangraw, P.E.
Message 3 of 9
(4,850 Views)
Here is the offending Graph.
Dan Shangraw, P.E.
Message 4 of 9
(4,846 Views)
Was it ever there?
Where did you get this graph from?
You probably need to just delete it and drop in a new graph.
Message 5 of 9
(4,840 Views)
Accepted by topic author ASTDan
I tried deleting and replacing the graph no luck
I have found Removing the Plot name from the legend causes the behavior.  Is this a bug or the desired functionality?
Dan Shangraw, P.E.
Message 6 of 9
(4,832 Views)
If I put a space in the plot name I can get it to work
Dan Shangraw, P.E.
Message 7 of 9
(4,827 Views)
Hello ASTDan,
It does appear that something odd happened when configuring this graph, my best guess is that someone attempted to hide the plot names and managed to lose the checkboxes as well - the ctl may even be partially corrupted, so as others have mentioned it may be a good idea to start fresh.
I was able to recover the names and checkboxes by toggling the "Plot Name Visible" Graph property, modified ctl attached.
Tom L.
Message 8 of 9
(4,824 Views)
Can you upload the VI ofcourse in 2011?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 9 of 9
(4,800 Views)
