Plot 2's compliment
Hi guys,
              i have a vi that gives me I32 1D array data out ( Long integer ) ... I want to take the two's compliment of this and plot a waveform.
If anyone needs my VI please feel free to find it in the attachment.
            Thankful to everyone who have helped me reach to this point.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 23
(4,131 Views)
The file to choose from the lib s FIFO interface.vi
Abhilash S Nair
LabView Gear:
Message 2 of 23
(4,132 Views)
XOR your array with the constant xFFFF.
Message 3 of 23
(4,118 Views)
I am guessing that you are probably talking about the two's complement. Which is spelled slighly differently.
If you read the wikipedia article, it is clear that your question is very ambiguous, because the term designates how binary values are interpreted as numbers and vice versa. Since you say you have I32, that interpretations is already done and negative numbers are already internally stored as 2s complement.
What kind of data do you actually have and what do you want to get out of it?
(If you habve a 4 byte string, you could just type cast it to I32, for example.)
Message 4 of 23
(4,116 Views)
I have something that says
1D array of Long(32 bit integer) as output. now I want to plot these data onto a XY graph that shows the two's complement of the this output.
Thank you
Abhilash S Nair
LabView Gear:
Message 5 of 23
(4,115 Views)
Can you be more specific. What is "something"? (e.g. Technical document? Homework assignment sheet?)
An XY graph needs values for x and y. You only have a single array. What is X? What is Y?
Does the array only contains two values where the first is X and the second is Y?
So far you make very little sense!
Message 6 of 23
(4,111 Views)
That is exactly what I want to know. I am sure this 1D array has values for both X and Y. I dont know how it is organised in this array.
As for technical detail. Please find the attached file and FIFO5_interface is the one I am talking about. If you open that VI . You can see the data result in the block diagram.
It is pretty complicated and I dont understand how this 1D array has elements for both X and Y. But if I plot the 2's comp of these values I get my original signal I want. and that is exactly what I need.
Please help me on this.
Abhilash S Nair
LabView Gear:
Message 7 of 23
(4,104 Views)
Does this mean that you are able to plot them and verify the correct result? If this is true then your problem is solved. Right?
Why do you say you still need help?
Message 8 of 23
(4,105 Views)
Yes now we are on track. I am able to plot BUT somehow the resulting waveform is supposed to be plotted in 2's complement format ... That is the only way to get the correct graph.
If I change the waveform graph to decomal, floating , ocatal, hex, binary... It wont result in correct waveform. I need to PLOT it in 2's complement itself.
PS: That is why I am breaking my head so much. There isnt any option in the properties of waveform graph to plot in 2's complement.
Abhilash S Nair
LabView Gear:
Message 9 of 23
(4,104 Views)
I think you are confused. Two's complement has nothing to do with formatting.
Can you attach a small picture showing what you mean? How should the graph look like? Do you want the axes formatted in a certain way?
Message 10 of 23
(4,098 Views)
