Please help me modify this code to write to the correct output channels
Oh wait, I just noticed you didn't need a shift register in your setup.  Maybe that's what was causing the issues with mine.  I'll try it more like this in the application.
Will this still work the same with the local variables?
___________________________________________________________________
Still confused after 8 years.
Message 11 of 12
(515 Views)
Yes.  It will work the same with local variables.
I got rid of them and used the terminals themselves because the terminals were sitting in the loop unused.  If you need the terminals elsewhere, or use the local variables elsewhere, then go ahead.  Just be careful with local variables because if you don't use them appropriately, they can lead to other problems such as race conditions.
Message 12 of 12
(505 Views)
