Piecewise function fitting
Please see the attached figure for the question.
I have this piecewise force signal as the function of time . The piecewise function is made of 2 lines:
One slope line is connected by one flat line.
From the raw data, or real signal, shown in upper panel, it is quite noisy. I would like to seek a solution to fit the data to the ideal piecewise function as shown in the lower panel.
1. How can reduce the noise, especially the high frequency components?
2. How can I get the turning point location and slope by fitting?
Any help or ideas will be appreciated, thanks!
Arnold
(3,297 Views)
How about a nonlinear fit where the VI model has the following four parameters (There are three sections, not two):
slope, offset, turning point1 (where it starts deviating from horizontal), turning point 2 (where it becomes horizontal again)?
(looking at your image, I think your model is an oversimplification of the actual data. What kind of experiment is this? Is there a more comprehensive theory?)
Don't reduce the noise, have the fitting handle the data reduction directly. Filtering noise always has a potential to bias the data in some way or another.
Can you attach a VI containing some typical data in a diagram constant?
(3,287 Views)
