Pie Chart?
Hi unclebump,
At first, I wanted to do this, but I don't know how to use the activeX chart object. When I insert the Miscrosoft Office Chart object in the container, what I am suppose to do after that? Where am I suppose to put the data for the chart?
Donald example is good, maybe I'm gonna use this one. Smiley Happy
Thanx again
Stephanie
Message 11 of 18
(2,781 Views)
which version of excel are you using?? It makes a difference which activex object you select.
Message 12 of 18
(2,778 Views)
Version 2003 SP2
Message 13 of 18
(2,776 Views)
I found this link but it was for an older version of the chart activex. I've been hacking on it trying to make all of it work with Chart 11.0 activex. I managed to make the pie chart work.
This is in 7.0 format
Message 14 of 18
(2,757 Views)
Hi uncleclump,
There is a wire conflict in MSChart.vi... and I coudn't fix it... I do have the MSOWC.DLL...
Any idea of what the problem is Smiley Surprised ?
Message Edité par TiTou le 06-15-2006 08:04 AM
Epictetus
Antoine Chalons
Message 15 of 18
(2,753 Views)
The reference input and output terminals are using the old chart class. Open the front panel and right click on the terminals, select activex class, and choose owc11.CH.Chart.  Wait till you see what this does inside the subvi to all of the property nodes. It is quite a pain in the butt.
Message 16 of 18
(2,768 Views)
Thanks for that quick answer it works now ! Smiley Happy
Epictetus
Antoine Chalons
Message 17 of 18
(2,762 Views)
Hi!  I am attempting to recreate a pie chart but when I include all the data that I see on the chart I'm trying to recreate it does not come out the same.  How do I "reverse engineer" a chart to figure out how it was done so I can redo it?  Thanks!
M
Message 18 of 18
(2,395 Views)
