Pick up values with mouse
----- Original Message -----
Newsgroups: comp.lang.labview
Sent: Monday, March 11, 2002 9:00 PM
Subject: Re: Pick up values with mouse
> Jack,
> Turn on the cursor. The cursor will display the x and y value in its
> display (when you also make it visible.) Then you can write the
> values down.
> Also, what values are you looking for. There may be a way for you to
> use a routine to search for certain values.
Thanks for answering
What I really wanted to know is that is it possible to get
the values under the mouse cursor into a table. So
there is a cursor display to mouse coordinates (x,y) but
I would like to get these values into a table 'naturally' by doubleclicking
the mouse over a certain point in
a graph.
Well I wonder if this is just a daydream ....:)
Jack
(3,214 Views)
If you belong LabVIEW 6.1, there is an example you can maybe adapt for your case.
This example is located here: Help->Find Examples...->New Examples for LabVIEW 6.1->Events->Draw Graph with Events.vi
I hope it will help you.
(3,213 Views)
Jack,
If you do not have labview 6.1 you can still get the mouse coordinates by using a call to the windows 32 API dll. There's a library called LVutil32.zip which contains a set of llb's and a dll(see instructions to install). One of them is the winsys.llb and there's a get cursor positon.vi:
http://zone.ni.com/devzone/explprog.nsf/webmain/ebf11dd1f0feaef3862566790072a983?OpenDocument
You can compare those coordinates to the cursor coordinates on the graph to correlate them.
There's also a VI that allows you to capture a mouse double click.
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/6b8cc338382df40786256a62004fa2ec?OpenDocument
Hope it will help.
Regards
Cyril Bouton
Active LabVIEW Developper
(3,213 Views)
