Physical Channel
     hi mike,
thanks for your perfect advice. finally, i got it.   frankly, u got it 😉
i have a last problem. u know, i'm reading AI but my value is changing +(-) 0.5 but i want to stable value. how can i see the avarage value ? i tired to use the "mean". but i couldn't do it.  Do u have any idea for this topic ?
thanks for your all reply...
hakan
Message 11 of 24
(1,549 Views)
Hi hakan,
you can change the read vi, to get more samples of one channel. Take the average of this samples.
Mike
Message 12 of 24
(1,545 Views)
        hi mike,
    Can i add 6 physical channels in one VI ?  i tired this but i couldn't do it. when i tired to fix the wire to physical channel - physical channel  it gave error   Smiley Indifferent
hakan...
Message 13 of 24
(1,543 Views)
Hi hakan,
what do you mean with 6 channels in one vi? I thought you have already 6 channels. Select 6 channels in your I/O control, then it should work.
Mike
Message 14 of 24
(1,538 Views)
      hi mike,
 i tired the your solve but the value is still change...  😞
 is there any word of command that takes average in the Labview ??   or ıs there any dıffırent way  to solve my problem ?
Message 15 of 24
(1,516 Views)
Hi hakan,
i mean somethink like this.
Mike
Message 16 of 24
(1,506 Views)
    hi mike,
thanks for your reply but i couldn't do it. 😞
why ?? :((((((
Message 17 of 24
(1,496 Views)
Hi hakan,
if you wanna use it, you have to change the type of the read vi to, "Multiple Channels -> Multiple Samples -> 1D Waveform", then you have it like the picture shows.
Hope it helps.
Mike
Message 18 of 24
(1,491 Views)
    hi mike,
i tired your advice but i still couldn't do it 😞
i tired two different way but it is not ok 😞
pic_1 : i can't read max. value bc it's read the value before multiplication.
pic_2 : i can't fix it.
thanks for your all advice....
hakan
Message 19 of 24
(1,473 Views)
Hi hakan,
insert the loop code before your calculations, so that the for loop is between the read vi and your add function.
Hope it helps.
Mike
Message Edited by MikeS81 on 07-08-2008 08:02 AM
Message 20 of 24
(1,470 Views)
