Peut-on créer un exécutable qui ne s'exécute pas automatiquement au démarrage ?
Bonjour,
Je viens de créer un exécutable, qui marche parfaitement. Cependant, j'aurais aimé éviter la première exécution, qui se fait de manière automatique au démarrage, et non sur demande par l'utilisateur. Est il possible d'éviter cette "première" exécution ?
Merci d'avance
Cordialement
(2,606 Views)
Accepted by topic author Evariste
Sorry, I will remake my question in english.
Can we avoid the automatic execution of an executable ?
I just created a program and I would like to avoid the "first" execution. This execution occurs when we start the program, and I would like avoid it to make the user enter datas before begin the execution.
Best regards
(2,602 Views)
You should have a look at your VI properties located in Source File settings =>Customize VI properties=> Execution=> Run when opened When you build the EXE.
Note that there is a French subForum
Rodéric L
Certified LabVIEW Architect
(2,597 Views)
Thank you for the reply. I will be more carefull next time
(2,591 Views)
if the answer solves your problem, you can pass the subject to "solved"
Spoiler
Rodéric L
(2,584 Views)
yes, sorry I make an another mistake Smiley Sad
(2,567 Views)
