Persistent copy of a reference?
Is there a way to make persistent copy of a reference to any VI Server object?
Consider this code (it is simplified idea of what I'm trying to archieve):
If I close reference in one process, it becomes invalid in other. Is there any way to prevent this? I mean - any simple way, something like SpecialPersistentCopyMakerMegaSecretStuff.vi, hidden somewhere in vi.lib?
(3,592 Views)
try to create a refnum for reference.
or try the VI server reference
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(3,582 Views)
Could you elaborate on this a bit more? What do you mean by "creating refnum for reference"?
(3,560 Views)
No.
The question shouldn't actually extend to all VI server references, because for many of them, the close primitive actually does nothing. But let's extend the question to references in general (queue refs, etc.) and then you have some options:
  1. Open a new reference to the same resource for each process. In this case, closing the last reference is generally what releases the resource. This is not possible with all APIs (DVRs, for instance).
  2. Do reference counting. That's a common way for managing something like this. Essentially, it's similar to what I described in the previous option, but you do it yourself. The basic idea is that each process that wants to use a reference tells a manager about it and the manager increments the counter. Every process that's done tells the manager and then it decrements it. When it reaches zero, the resource can be released. This manager can be a separate process, a functional global, etc. You can read up on ref counting to see more.
___________________
Try to take over the world!
(3,558 Views)
