My main vi of a tensile tester control application calls a number of sub-vi's, including a analog control loop which controls the test. The control loop must update some boolean and digital indicators and respond to user input on the front panel of the main vi during a test.
To simplify my main vi, I moved the control loop code into a sub-vi, and used control references to access the controls and indicators on the front panel. However, this has dramatically affected my loop performance, and the loop can no longer keep up with the acquisition speed.
Do control references always cause such a slowdown? Is there anything that I can do besides moving the code back into the main vi?
Thank You,
David Creech
