cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Performance between LV6.1 + Mac OS9 and LV7 + Mac OSX
I use a PowerMac G4 bootable on OS9 and OSX (10.2.8). I run one application (G progamming + CIN) on the 2 OS (one in LV6.1 and one in LV7).
My application do Real Time analyse. My problem is performances are better on OS9 than on OSX !!!
I don't understand why? Anybody has a little idea of the origin of this mytery ??
Thanks for all help.
PS : The same test on a PC on XP pro + LV6.1 and Linux RedHat + LV7.1 give the same performances on the 2 OS...
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
0 kudos
Mensaje 1 de 3
2.721 Vistas
Are you sure that your are running LabVIEW 7.1 on RedHat, and not 7.0?
I don't have a mac to test with, but have you narrowed down the area in loss of performance? Do you think it is in your G code, or the overhead of using a CIN?
Do you think you could create a small demo VI that demonstrates the behavior, and then we might be able to find out why.
0 kudos
Mensaje 2 de 3
2.721 Vistas
Of course it's LV7.O + RedHat 9, sorry...
I haven't narrowed down the area in loss of performance :
- profile VI --> approximativly the same result on OS9 than on OSX.
- small VI test on part of code --> performances are egual or better with LV7 on OSX !!!
- modification of the excution thread or/and priority --> not conclusive. (On RedHat, this modification is radical for the increased of the performance !!)
- compiling the CIN with speed optimization --> not conclusive...
The last thing I think, it's that run OSX is more expensive in CPU time than OS9... Is it possible? how test it?
I hope this is not a problem like this, because I can't optimized it !!!
Olivier Jourdan
0 kudos
Mensaje 3 de 3
2.721 Vistas
