Pendulum Error Query
Hello, this is some C code I inserted inside a formula node for a pendulum. It comes up with the error shown in the second screenshot, and I'm not sure what to do about it as I've copied exactly the code from a manual we were given.
Thanks 🙂
(2,859 Views)
Accepted by topic author IsobelMunden
Hi Isobel,
What about that missing variable "theta0"? It isn't defined anywhere in this formula node!
(Check the naming of the formula node input carefully…)
(2,849 Views)
Thank you!!
(2,843 Views)
If GerdW's answer fixed your issue then you should mark it as the solution.
(2,820 Views)
