Peak detection at same time
Hello
I have two wave A and B with 10000 sample point.
Now I want to find Max and Min peak value from wave form A and correspond to it I want to know respective value of wave B.
So at thw end finally I will get Max value of A and it's respective value of B.
So for that I want to know basic idea.
(2,549 Views)
-I guess similar type of questions have been asked and answered many times.
-Check these for getting max and min peak values
http://zone.ni.com/reference/en-XX/help/371361H-01/lvwave/waveform_min_max/
https://decibel.ni.com/content/docs/DOC-10515
-Then use time value where peak happens in wave A to wave B and get the values.
uday
(2,540 Views)
Accepted by topic author hussey
After the waves have sampled. Just use "Array Max & Min" on the A array, or peak detection
Then connect the indexes of the max and min to "Index Array" of the B array.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(2,540 Views)
Hello
I think there is one misunderstanding by you,
I want value of Wave B(whatever not necessary that both wave will give me Max and min point at same sample point) when I got Max value of wave A.
(2,523 Views)
That's exactly what got explained, or showed by me and uday.
(2,519 Views)
-First get the max value where it happens in wave A.
-Use that time value in wave to get value in wave B using simple index array.
still not clear?
uday
(2,515 Views)
