Peak Value of a signal
I have a signal which was collected from an experiment. Let us assume that I have converted it into the frequency domain(through FFT for example). Is there any way I can find the frequency which has the highest amplitude/power purely through labview and display it in the form of numeric data?
(2,600 Views)
The output of an FFT is an array of counts/occurrences of frequencies.  Simply use the Min/Max function to find the peak number of occurrences.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,581 Views)
In the future you should give a little more information about the format of the data you are using. Including some code is also usually a good idea.
Here are 2 examples of pulling a fundamental frequency from time-series data.
Dan King
(2,575 Views)
