Peak/Valley Detection
I am using LabVIEW 2019.
I am having an issue detecting two points in an array. I want to measure the time of the two points that are marked in the picture below with the two yellow lines. I tried using peak/valley detector to find the two minimum points, but as you'll see, both the noise prevents an accurate reading at those points. I would even be fine with just detecting when the waveform reaches the minimum point just after 10ms and when it reaches steady state at zero. The data I am using to test this is from a random current waveform, I got from a different test. I have attached the data and the vi to this message. The goal is to read any array that has a trace like this and output the time difference. In the data, there is a few different traces that all look similar but happen at different time lengths.
(2,202 Views)
If the curve is always going to look like this I would reverse the data and start at the end and work my way back to find these points.
Tim
GHSP
(2,175 Views)
