11-01-2006 06:03 AM
11-01-2006 07:36 AM
11-01-2006 07:52 AM
11-01-2006 09:25 AM
Hi Adam
Right, I've changed the vi so the delete from array is now in there. I can see how the vi is meant to work now but I get the attached results. Thanks so much for your help - its awesome!
Cheers
Dave
11-01-2006 09:40 AM
11-02-2006 04:08 AM
11-02-2006 06:01 AM
Awesome - Adam your a star - got the code working in isolation in the vi at the moment and its just great - seems to be alot quicker than my last attempt. Now I just need to try it in the main vi.
Cheers
Dave
11-02-2006 08:17 AM
Hi Adam
Quick question - I've put the vi into my main vi and I'm testing using some files. I get the following processing times out -
File 1 - 1.5mb - 9s
File 2 - 2.6mb - 70s
File 3 - 3mb - 90s
Do these times look in proportion to you? Seems to be a massiv difference between the first file and the rest..
Cheers
Dave
11-08-2006 04:30 AM
Hi David,
Sorry it's taken so long to get back to you. (I've had one of those weeks)
Anyway, the times seem to be quite out of proportion. Where in the code is the largest drain on time? If you place your code in flat sequences and measure the time it takes for each of these to complete, you can narrow down the problem further. Have a shot at this?
Have you had any more luck with all of this? (I get the feeling that the "time hungry" code will now be in the power spectrum vi and the average level vi's)
AdamB
11-13-2006 07:19 AM
Hi Adam
Now worries - my last week has been the same as well - hence my delay! I will try and have a look at this in the next week - too many other things getting in the way at the moment!
Cheers
Dave
