Pausing DAQmx between loops
Attached is what I ended up with. I used the advice of the other users to (1) change my DAQmx read VI to "Single Sample Waveform" and (2) used a wait (ms) function in a flat sequence with a DAQmx stop VI followed by a play VI in the subsequent frame. I'm sure there's a simpler way to do this, but this worked for me. Loop times are consistently 25 seconds (20 seconds acquisition and 5 seconds rest) between trial loops.
Message 11 of 13
(453 Views)
Also thank you everyone for your patience.
Message 12 of 13
(452 Views)
The last paragraph of the Solution gives two methods to fix this (I know, because I wrote it ...).  Sometimes a Thousand Words (well, a few hundred) are Worth More than a PNG, particularly if you are trying to teach someone how to "Think LabVIEW".
BS
Message 13 of 13
(450 Views)
