Pause a clock with elapsed time function
Hello, I'm trying to implement clock function with start/stop mechanism. I need it to be done in the way that clock is located inside the case structure (see pictures). The idea is that present time compared with previous iteration time and if it more than 1 second, difference is added to start time and written to start time terminal in elapsed time function. However, it does not work as it should. Can't find the reason. Any suggestions?
(4,588 Views)
Accepted by topic author sergi22
The Elapsed Time already does what it looks like you are trying to do.  Use a single shift register to hold a Boolean.  When not paused, just write a TRUE to the shift register.  In the paused state, wire this shift register to the Reset input of the Elapsed Time.  This will set the start time. When paused, write a FALSE to the shift register.  Then you just need to look at the Elasped Time and the Time Has Elasped outputs.
(4,560 Views)
Hello
(4,546 Views)
