Pause.DigLvl.When
Hey
Using the above DAQmx Trigger Property Node with 'Pause.DigLvl.When' the PWM signal under question seems to randomly stop in either a high or low state when paused, even with the '10214' numeric inputted to the node, or a created control and selected in Low state. This random behaviour also happens when parameters are changed to select 'high' state stopping.
Any help would be appreciated.
Skyman
(2,577 Views)
Hey Skyman,
I have tried out the pause trigger on a continuous pulse train generation, and it has worked as expected. When I set the pause trigger line (PFI0 in my case) high, the last generated digital value will be held until the pause trigger is set low. I have attached my simple little application.
As you will see in the attached screen cap, I have hooked digital line 0:0 to the counter0 output. I then connected digital line 0:1 to the PFI0 line of my card. Using the test panel in MAX I can see the counter output oscillate at 1Hz, until I set line 0:1 high - at which point the counter out will hold the latest value, until is set line 0:1 low again.
Please try this out, and let us know how you get on.
Best wishes,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(2,530 Views)
