Pattern Matching or Golden Template
Hello all,
   I posted a question earlier on what advice can be given for hardware that could be used to acquire a fingerprint. I got a very helpful answer. Now I'm still working on this fingerprint recognition project and have been looking around into the logic to be used on matching images. I came across both the "pattern matching" and "golden template" available features on NI Vision assistant and was hoping someone could point me on the right direction so that I could obtain more insight information on how either one of these features perform their matches.
Thank you,
OC
(4,626 Views)
Accepted by topic author Mr OC
Hi OC,
Included with NI Vision is the 400+ page Vision Concepts Manual.  This explains in detail all of the functions available in NI Vision, including Pattern Matching and Golden Template Comparison.
This document can be found in <Program Files>\National Instruments\Vision\Documentation\Concepts_Manual.pdf
Chris Bolin
LabVIEW Partner Program, CLA
(4,603 Views)
In my opinion, this situation is a good fit for a Golden Template, and this is basically a complex subtraction technique between your "golden" fingerprint, and the inspected print.
I think the best approach is to define exactly what you want from your program, and test both types of matching.
Chris Bolin
(4,597 Views)
Hello Chris,
   Sorry for the late response.  I wanted to thank you for sending me on the right path. I have started taking a look at the documentation and it is definitely helping my understanding of how they each work.
Thank you,
OC
(4,551 Views)
No problem, OC!
Chris Bolin
(4,527 Views)
