Pattern Matching VI not visible
Hello all,
I have installed VDM,VAS and VBAI software but I am not able to see match pattern VI ? I am using 2011 and all software installed successfully.
Any ideas?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,566 Views)
Have you tried the search of the function palette?
Ben64
(3,537 Views)
Yes I did, In vision and motion --> IMAQdx. its not there. Is any problem with version difference becasue when I saw in program files then labview 8.5, 8.6,2009,2010 folders are present. Surprised Smiley Surprised
--Ranjeet
(3,510 Views)
And also other palette like image processing, IMAQ io is not visible as I installed VDM, VBAI and VAS. Attached image file for reference.
--Ranjeet
(3,506 Views)
Insert Device Drivers DVD and install
--> NI-IMAQ
--> NI-IMAQ I/O
--> NI-IMAQdx
Don't forget to select LabVIEW support for appropriate (installed) version.
Install IMAQ
I've never seen you giving KUDOS to anyone...!! OR even marking a reply as solution...!! any specific reason???
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,490 Views)
By mistake I installed the older version of VDM, Now it came
I never know someone is following me from so long time. When I feel to give I will.There is no specific reason or bad intension like Smiley Mad.
Thanks.
--Ranjeet
(3,456 Views)
