Path format in vxWorks
Hi folks,
I am developing code for a cRio-9014. I understand that this uses vxWorks as its OS and, because of this, uses the unix path convention. Being a'nix-head myself I thought I would be happy with this. I also understand that the system needs the filename to be absolute with the full path from the root directory.
I wish to access a file on the built-in flash drive called 'initialisation.cfg' that is in a directory called 'SetupData' directly under the root directory. Thus I would understand the required filename to be '/SetupData/initialisation.cfg'.
The system is unable to find the file though. I have tried many variations on the above path & filename with no success. Could somebody give me the correct path/filename to use and tell me where I am going wrong?
Cheers, kimdino
(5,023 Views)
Hi again,
Have I put this on the correct forum? If not, then where should it go?
Since the original posting I have tried a few more things. A common theme I see involves a mystery directory called 'c' (e.g. /c/FirstSubdirectory/File.conf) as if this was hung under the root. Is this for MS-Windows users who might expect a C partition, though I can't see what function it serves in a vxWorks cRio. Anyway, I tried it prefixing my path with '/c' but this did not make it work. Has anyone any other ideas, please.
Cheers, kimdino
(4,947 Views)
Accepted by topic author kimdino
If you are creating your folder say, setupdata at root ie c: on the cRIO target then the file path convention would be c:\setupdata\filename or if under ni-rt then c:\ni-rt\setupdata\filename , LabVIEW will handle the file path convention on its own.
Try and let me know if this was useful
-Mallya
" Appreciate and motivate those who help"
(4,942 Views)
Hi mallyaprs,
That did the trick. Using an MS-Windows style path structure on a 'nix-based system, I would never have thought of that. I could only think UFS - hmmm.. Anyway, it works and that's what matters.
Many thanks,
kimdino
(4,914 Views)
