Passing the result of a sub VI with event structure back to the top VI
Hi All
I am experimenting with using event structures in sub-VIs with the eventual goal of consolidating a very large control system I am working on.
Attached is the toy-model I am working on. The VI works in the sense that the top level VI can control the the sub level VI, but then I want to pass the results back to the top level -- in this case it just a a Boolean LED indicator. I think I could achieve this using a refnum indicator and then converting this to boolean with a property node in the top level VI but this feels a bit clumsy.
VIs are attached!
(3,322 Views)
Yes.  You need to pass in refnums of your indicators on the main VI.
This isn't clumsy.  What is clumsy is having a subVI that runs forever.  Your main VI can technically never end without aborting your program because once it calls the subVI, the subVI has an infinite while loop.
(3,318 Views)
Okay I see. What would you suggest to implement what I am trying to achieve in a better way?
(3,315 Views)
I don't really know what you are trying to achieve.
Why do yo have a subVI with a while loop in it?  Not that you can't do that, but when you do, you are going to treat it like a parallel process. That means not having indicators directly based on it by way of its connector panel.  Also you need a communication mechanism to tell it when to shutdown.
(3,310 Views)
Essentially code reduction. I am redeveloping a very large control system. This system currently has about 20 different event structures each containing relatively complex code. I want to bundle these individual routines up into subVIs to make everything more manageable, hence my experimenting with the attached example.
(3,302 Views)
I guess this is a continuation of this earlier discussion. Why not keep it all in one place?
(3,287 Views)
