Passing dynamic captions from program to program
I am trying to construct a relatively simple program to read back captions dynamically. Program1 will get the values and caption names from a secondary program called Program2 using an invoke node method. Program1 will then readback the captions and values using a property node. Ideally, I will be able to add an event structure for both programs, so that I can update the values and captions between programs.
The problem I am running into is that when I change the name of a caption in Program2, the updated name does not get reflected back in the first program. I know that LabVIEW cannot dynamically change a label, but I was under the impression that it was possible with captions. I'm not sure what I am doing wrong, but I can't seem to get the program to work correctly. Thanks for any feedback.
 The two programs are attached below.
(2,868 Views)
Accepted by topic author Newbie217
Hi Newbie,
      The attached VI shows one way to obtain the captions of controls on another VI's front panel - is this what you want to do?
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,850 Views)
Hi tbd,
Yes, this is exactly what I was trying to do! Thanks so much for the solution! It works perfectly. Cheers!
(2,831 Views)
