Passing data through TCP/IP
Hello ! My challenge is this: I have a vi that i have to use as a server and a vi as a client. In the server vi, i want to modify multiple parameters of one graph and these modifications should reflect on the client vi. How can i transmit, through TCP/IP, the modified graph to the client vi/application ? I would appreciate very much a link or a example vi that can show me exactly how such an opperation can be achieved. Thank you!
Message 1 of 11
(4,725 Views)
There is a good example doing this on the example finder.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 11
(4,717 Views)
Hello ! Quick answer 🙂 Thank You. what should i look for ?
I have already looked at the exemples of TCP/IP server /client configuration examples...but i didn't find anything...I may have missed that example...could you (PLSS) be more specific ??.. Thank you very much !
Message 3 of 11
(4,710 Views)
Are you looking to transmit the properties of the graph or the data.  I might have misspoken.  You can send a string over TCP capturing these properties, parse them at the client and write the values to the correct property node.
Paul Falkenstein
Message 4 of 11
(4,708 Views)
Both ...the data& the propeties of the graph...if such a thing is possible.
Message 5 of 11
(4,707 Views)
I have just started 2 work in LabView...I don't have much experience ...so an example or a walk throug woul be very much appreciated...Thank's for taking the time to answer my question.
Message 6 of 11
(4,705 Views)
You can make the string you pass include any data.  Here is a simple example using an XML string.
<Graph>
<Value>1,2,3,4,5,6</Value>
<Visible>True<\Visible>
</Graph>
Send this string on the server side taking a reference to a graph and build a simple vi to generate a string containing  the data you want to send.
At the client side you parse this string an a loop as set the appropriate property node as the tag dictates.
I cant think of a precanned solution for this but my morning coffee has not kicked in yet.
Paul
Paul Falkenstein
Message 7 of 11
(4,702 Views)
Thank's !!
Message 8 of 11
(4,697 Views)
For just the data the examples are the 'simple data client' and 'simple data server' examples.  Sending properties are a little harder.
Paul
Paul Falkenstein
Message 9 of 11
(4,697 Views)
Would it help if i posted my vi's ?
Message 10 of 11
(4,692 Views)
