05-17-2011 12:27 AM
I'm trying to pass an array of clusters to a DLL but it doesn't get passed correctly. I have passed a few clusters similar to this (although smaller) with no issues before, but somehow this one doesn't line up correctly or something. What I'm trying to do is passing an array of items followed by a info struct. The length of the array is the nItems param in the info structure. The problem is that when reading nItems in the cpp code it doesn't match with the value passed as you can see in the log file when run and from the assertion error. This indicates that the structures are not passed correctly.
It looks to me that the cluster matches the struct definitions and I'm pretty sure I'm using the correct parameters in the CLN. I have had trouble before with large clusters where labview would get confused and I'd get instane objects issues but I'm not sure if that's the issue here.
h file
#pragma pack(4) typedef struct TKdlgItemVal { int intVal; double doubleVal; char szVal[256]; } TKdlgItemVal; typedef struct TKdlgItemConf { int nType; // The item type code (see below), replaces nParam2 double dX; // Item x position or 0 for default layout (was dParam1) double dY; // Item y position or 0 for default layout (was dParam2) char szText[256]; // The prompt string for the item, following | then tooltip is optional double dWide; // Item width in dialog units. double dHigh; // Item height for group boxes only. double dLo; // Item value limits for reals and integers. double dHi; double dSpin; // Spinner value or zero for no spinner. int nPre; // Precision for real items & max chars for string (0 for don't care). char szList[1024]; // Selector list - items separated by | char. Required for list type. char szLegal[256]; // Legal characters for string type, leave blank for all legal. TKdlgItemVal sDlgItemVal; } TKdlgItemConf; typedef struct TKdlgInfoConf { int nItems; // The number of dialog items double dWide; // Dialog width double dHigh; // Dialog height char szTitle[60]; // The dialog title } TKdlgInfoConf; #pragma pack() extern "C" __declspec(dllexport) int setS2Dlg(TKdlgItemConf asDlgItems[], TKdlgInfoConf sDlgInfo);
cpp file
extern "C" __declspec(dllexport) int setS2Dlg(TKdlgItemConf asDlgItems[], TKdlgInfoConf sDlgInfo) { std::ofstream myfile; std::vector<TKdlgItemConf> m_asDlgItems; myfile.open ("logger.txt", std::ios::out | std::ios::app); myfile<<"NItems: "<<sDlgInfo.nItems<<std::endl; m_asDlgItems.clear(); if (!asDlgItems && sDlgInfo.nItems) // Array not empty yet is NULL return 1; ASSERT(sDlgInfo.nItems<11); m_asDlgItems.reserve(sDlgInfo.nItems); myfile<<"RSize: "<<m_asDlgItems.capacity()<<std::endl; for (int i= 0;i<sDlgInfo.nItems;++i) { m_asDlgItems.push_back(asDlgItems[i]); myfile<<"RSize: "<<m_asDlgItems.size()<<std::endl; myfile<<"RSize: "<<m_asDlgItems[i].nType<<","<<m_asDlgItems[i].szText<<std::endl; } m_asDlgItems.shrink_to_fit(); myfile.close(); return 0; }
Thanks in advance,
M
Solved! Go to Solution.
05-17-2011 02:02 PM
I wish I could delete this post because I feel very stupid. It was a simple case of passing a cluster to the CLN but I forgot to set the params in the c code to pass by pointer instead of by value...
