Passing an entire array into a for loop multiple times
Hey guys,
So I have a 1D array that I want to pass into a for loop. I want all values of the array to enter the loop on each iteration. However, as soon as I send the array in, it automatically auto indexes and sends one value at a time.
What's the fix to this?
I have looked at a few previous threads but most were asking how to send individual values instead.
Ideally, I am trying to send a 1D array in that multiples all its values with the cosine of an angle. I am using the for loop to update the angle on each iteration, but I want the 1D array to stay the same and enter the loop as a whole (as opposed to one value at a time) on each iteration.
Any help/guidance would be great.
Thanks 🙂
(2,775 Views)
Right-click the tunnel and disable autoindexing.
(Instead of lengthy descriptions, show us the code instead. There might be other issues)
(2,770 Views)
Thanks.
I just figured it out a few seconds ago too.
(2,767 Views)
Again, from your description is it not even clear why you would need a FOR loop at all. Can't you just multiply the array with the scalar angle?
(2,763 Views)
Trying to multiply the same array with various angles to see if there is any advantage.
(2,761 Views)
