Passing an array to a formular node
I have a 2D array and I want each number in the array to pass through the formula, with the output of the same array with different values
Message 11 of 12
(499 Views)
Then you should be able to set up the declaration for the output variable, and the loop code in the formula node just like I showed in the earlier post.
Message 12 of 12
(498 Views)
